Help 2.1 firmware versions for spica
Sister Bob
Hi everyone! I'm new as you can see and I have some questions that I hope I can get some answers to. Also, I hope that I'm not starting up a topic that already exists, but I couldn't find anything that answered what I wanted to know.
Anyway. I just purchased my Samsung galaxy Spica a couple of days ago and was planning on rooting it/upgrading to 2.1. However, after looking around, I see that there are a bunch of different firmware versions for Android 2.1 on the Spica. I understand why there are different versions, my question is: which one is right for me? Are some faster than others? Is there one that works best on a Canadian (Rogers) Spica (which is what I have)?
I'm just trying to make sure I'm doing the absolute best thing in terms of upgrading before I go ahead and void my warranty. Also, is there anyway for me to backup an exact copy of my current 1.5 with all the rogers stuff that I can put back later? Can I ever un-(or de-)root? I'm just a bit worried that something will go wrong one day and then when I bring it in they tell me my warranty is void, tough luck, etc.
Uhm... Yes that's all I wanted to say. Thanks a bunch either way!
Most of your questions ARE answered in other threads.
See this thread started by a Rogers user. HERE
Other Canadian Rogers users have updated their firmware to 2.1. All you need do is install firmware, set to English, and enter your (Rogers) APN (Access Point names) settings.
You will find your current APN settings
Menu
Settings
Wireless & Networks
Mobile Network
Access Point Names
Your Provider.
Forget rolling back to 1.6.
If you want to backup your data,
I wrote some backup instructions Here
If you do update your phone, and subsequently root your phone, yes you can roll back to previous firmware, which depending on that firmware will (un-root) you phone again, although not rollback to Rogers 1.5.
Thanks a lot. I actually found that thread just a few minutes ago, too. Sorry :o
I'll post how everything went later on tonight; I'm pretty excited.
Just finished upgrading, everything seems to work well, if slowly. 1 odd thing is that the market shortcut disappeared from the desktop randomly but other than that.
Just need to get everything else up and running (live wallpapers, etc)
Thanks for the help, Beerkan.
Edit: It appears that I can't access the internet at all through the rogers network... I wonder why that is?
Just to clarify, and as a Rogers user, can you confirm
WiFi, GPS, GPRS, MMS, SMS, Google sync ALL work ok?
Hm GPS does not seem to respond at all... It just sits there trying and trying but never gets anywhere. SMS, WiFi and Google sync are all fine, however. Haven't tested MMS and am unsure as to what GPRS is.
