2.1 help ?
hey everyone
actually i have downloaded the 2.1 update from
http://www.gsmarena.com/android_21_goes_to_motorola_milestone_overtheair-news-1544.php
note that i am with telus and when i downloaded the update and pressed power and X nothing happened so i did power and the camera key and there is an option that says apply sd card update.
when i do taht it says the following well the first thing it says is ....
E: Cant open /cache/recovery/command..then
E: Failed to open /sdcard/update.zip (no such file or directory
E: Signature verification failed
Installation aborted....???
hey everyone
What you have there is a .sbf file which must be flashed to the phone using RSD Lite. This thread will explain how: http://androidforums.com/all-things-root-droid/47349-now-you-can-live-without-fear-bricking.html
I'm assuming if you aren't with Verizon you have a Milestone and not a Droid. That's what that file appears to be for. Is this correct?
