2.1 Leak question
drdolil99
I installed 2.1 v3 Leak and my charging port on my phone isn't working. I called verizon and they are sending me a new phone. is there going to be a problem when I send it back?
To fix the issue your having try plugging your phone back in the computer and select charger only,which will pop up on your phone when you plug it in,then before you unplug it make sure you click remove hardware which is located at the bottom of your screen right hand corner...
You phone isnt charging due to the fact that its in disk drive mode.
In order to get my charger to work I have to physically wiggle the charger in the port. Once I get it in the right position the light will come on and it will charge and I can use it.
