surgeon0214
Any buddy hear anything about the 2.1 leaks being rooted? Or are the devs just skipping that and rooting the official 2.1? If you know anything please post below.
The official OTA basically came rooted - the same method that was used to root 1.5 worked as long as your update to 2.1 was done via the official OTA update. Those of us who were inpatient (myself included) and used the leaked updates, it changed the HBOOT version, making the existing root method useless.
As far as a method to root the leak, as far as I know, none has been found yet. I'm sure when one is available it will be all over the place. Many, many people want it. There is always the 'ebay shuffle' method; buy an eris on ebay (make sure it is a version 1.5), then just sell your leaked one back on ebay afterward. It will cost you maybe $20 in the end, if that...but a bit of a hassle though.
Thanks man, but I remember a while back some dev at XDA found a possible way to root but I guess there hasn't been much progress...
