2.1 Lock Screen
kizer8
Hello,
Is there a way to add the colorful 2.1 Lock Screen to my Droid X with Froyo 2.2.1? I like how colorful the 2.1 lock screen is compared to the black Froyo lock screen.
Thanks,
Kizer
not without rooting and a custom rom.....or you can do the easy method and buy widget locker from the market. worth the money. you can change the sliders, use a different lock screen background, get rid of the vibrate, add sliders for opening apps, add apps and widgets to the lock screen...totally worth the $3 or whatever it is.
