Ever since I downloaded the new update for my backflip my phone has been so slow its crazy. it takes a few minutes for any application to load.. sometimes it doesn't let me answer my calls. what should I do?
I found it best to do a factory reset after the upgrade to 2.1. Then re-install your apps one by one to see if any are slowing it down. Are you using handcent by chance? I found it caused my phone to lag when answering calls. I removed it and it seems to by fine now.
