2.1 ROMS and bluetooth issues?
soonrfan
I have tried both Fresh 2.0d and Damage 2.06. Both ROM's are great BUT I am having a strange problem with my bluetooth. I have a home wireless BT system where the cordless phones automatically link to my Hero via BT. This works perfectly in all 1.5 ROM's but for some reason when trying 2.1 ROMS, does not work. Another strange things, when on 2.1 and trying to connect to my Plantronics BT headset, works fine. Just does not line up with my wireless phones.
I have tried everything I can think of... cleared out all BT connections and started from scratch but no luck.
Any thoughts?
yes, this is the latest build of the entire phone from Sprint for 2.1. This includes the new radio version that you posted.
So the latest RUU is separate from a ROM, say from flipz, correct? Would I flash this first then flash back to the 2.0d ROM?
no this is a file you download on your computer. You run it and it will do it all for you. It will wipe the phone and upgrade it to the latest 2.1 build that Sprint had, or at least the one that all the latest 2.1 builds were based off. Once you do this, you wouldn't need to reflash 2.0d as that would replace this.
