2.1 update connection error
Lozer_Kid
So, I've been trying to get the official 2.1 update on my phone, but everytime I do, I keep getting the 170 error, which is an error connection from my USB port. I know that the USB ports are fine because other flash drives work fine, plus my phone shows as connected on my PC. I already tried rebooting my PC and phone the RUU software still wont recognize my phone and just tells that there's an error connection. Any help on this?
I already tried mounting my phone from the phone settings...
I think I got the full one because the file size is 118 MB, but I'll try this one and see if it works, thanks!
Yeah, mine said it was complete too but there was something amiss for sure. The mirrored copy was the third d/l for me and that finally worked. Let me know.
I downloaded the mirrored copy and it's still telling me that there's no connection when there is... :(
hmmm... sorry, that that would do the trick for you since I was stuck on the install until I got that version of the file. Sorry, I don't have any other thoughts right now.
I don't know what it is and I'm getting quite frustrated. I just tried a different windows computer and I still get the same problem! If there was no connection, then I'm sure my phone wouldn't even show up on either of my computers! Not even on my mac... I guess I wouldn't be able to transfer files from my phone to my computer and vice verse either... :(
you gotta connect your phone using Sync
Thanks, that actually helped solving my problem! Now, my phone it's finally updated :D
Similar problem here.... my phone says it cannot sync :mad:
You need to instal the the HTC Sync software, otherwise it won't sync. The software should have come with the original 2GB Micro SD card, in the HTC Sync Folder. If you replaced that card with a new one, then you need to get the original SD card, or download it from here HTC Hero - Application Upgrade - HTC Sync 2.0.33, make sure you pick the US version. After you installed the software, make sure to reboot your computer, otherwise it still wont Sync. Once your computer has been rebooted, just go through the Set up wizard and ta dah!!! It should work after all that! =]
I downloaded the Sync just a few hours ago. Still won't sync my phone. Which is weird... because I have never had a problem syncing before.
Well, I'm not sure then. I installed the Sync software that came in the original SD card, I didn't download the one from the HTC website! Maybe, you should try installing the one that came in the SD card. I'm sure the software are not the same.
Hey Kid sorry, I assumed you were doing that part or I would have been able to put it out straight away last night.
That's okay, at least we got it figured out and I really love the 2.1 update despite the bugs that it has!!! :D
Hey,
I have a similar problem like u guys, but mines kinda worse i think.
When i connect my Hero to the PC, Htc Sync finds it and its all good.
BUT just as i run the RUU it turns off ! Then theres suddenly NO connection between Sync and my Hero O.o ... I got the ADB driver and windows sais it works, and it should since it connects with Sync.
Can anyone help me plzz ?
Same problem here. I finally gave up.
I'm taking the hero to Sprint and letting them do it.
I ran into the same issue when trying to reflash from 2.1 to 2.1. I finally got it to work after booting the phone into safe mode and then running the RUU. To boot into safe mode, power on the phone then hold down the Menu button until the phone boots up. You will see safe mode on the lower left side of the screen.
Er, I am trying to reflash again, but the safe mode trick isn't working for me.
RUU connects to the phone and so does sync, but once the phone reboots it never goes into the boot loader....
Any ideas why?
I had the same problem, use the 2.0.3.3 version of Htc Sync, thats what did it for me. Also, I had to change the connection type to Htc sync in the pull down notification window on the phone before it would recognize the phone, good luck.
