Help 2.1 updating is so confusing?.
Dnj
Member
This 2.1 updating is so confusing?. Can I just bring my Moment into the Sprint store for the upgrade. I'm now wondering if its worth it or should I just keep the 1.6 OS I have with no problems?:confused:
thanx
I don't find the update procedure very confusing, just follow the steps. If you want to update in store, non repair center may not be able to do it and it would be a good idea to call ahead regardless. If you try to do int yourself and have problems, there are plenty of people here who will (attempt to) help. Also, you have 1.5, 1.6 was never available for the Moment.
What part are you having troubles with. We'll help you step by step. Others might benefit from this too.
I am not too good with this stuff......I have never done anything with the phione Via the computer, USB, etc ...I always take the card out of the phone and upload files songs etc...direct to the card. But Im willing to try with your help
Thanx
there is no 1.6 for the moment, as for the confusing part just ask for help, you may even be able to chat live.
