Root 2.15.00.09.01 Radio
djl236
Member
Anyone know if there is any benefit of upgrading the 2.15.00.07.28 Radio (one I'm currently running) to the 2.15.00.09.01 radio?
Seems like it improved my reception some but I suppose it could be a placebo effect. I tried it just to see if it would make a difference. I really don't think it made much of a difference though. Some of the new roms being released recommend this radio update before installing for some reason.
Well as long as no one is seeing anything negative from it, I think I'll flash it.
My reception has definitely improved, I can confirmed that. I was sitting in the similar spot while holding my phone in the similar spot, I took notice on the signal, before and after, it's about +6 dBm.
just flashed it, FWIW signal went from -69 db on 2.15.00.07.28 to -66 db on 2.15.00.09.01, GPS, camera and camcorder all working just fine on latest Skyraider with Sense and kings kernel #5.
You do realize +6db is worse......
Did you mean your db level dropped -6db (ie -80db to -74 db)?
are you saving the zip file as PB1IMG.zip and booting into Hboot? I don't know why it would tell you it's still the old version. I flashed it recently so I could flash the Incredible Does ROM and it worked fine for me.
Are you S-OFF?
