Root 2.2.1 Recovery Flash Needed/Question
Bad300z
I'm rooted on 2.2.1 MS690ZV4_26.6050 / Kernel 2.6.32.9 (Build1) / FRG83. Using the posts here I was able to get it rooted but no service, then fixed that but then had no recovery but with Joneidy 2.2.1 recovery now I got it all workin. (Awesome by the way! Keep it up) Tried the Sense ROM and Gingerlike ROM, ok but didn't see much benefit. Anyhow, to the point. With the image I am running now, I accidentally killed TTSSERVICE, I mean blasted it, uninstalled.. Which sucks. I was wondering if someone had a setup similiar to what I have running (even if it has the bloatware on it) that they could post a recovery flash for me? That way I can get my TTS back without having to go and mess with re-rooting, fixing recovery, etc? I'm pretty new at all this but not completely stupid.. Thanks for any help in advance.
J
If I flash it yes it does fix the problem but I don't like the bottom bar I.e. phone.e menu etc its ugly and annoying so just wanted to flash back to stock 2.2.1 rooted and fixed recovery etc.
You just install a new launcher then use root explorer to delete the sense launcher easy
see what i mean im using sense rom but deleted sense launcher after i install a different launcher from the market. you can delete the sense launcher with root explorer or you can keep both just choose which one you want to set as your default.
