Help 2.2 EVO Bluetooth Problem - Audio Cuts Out!
leebo
This issue started after I installed Froyo from Sprint. My audio cuts in and out, although the person on the other end hears me fine.
I've tried re-pairing but it didn't help.
I'm using the original Jawbone headset.
I have an original jawbone and it works fine for the most part, however if someone else calls while I'm already on a call (call waiting), my jawbone speaker cuts out. The other caller can hear me just fine however, and to bring it back, I have to toggle the bluetooth headset audio off then on again and it's fine. This is a very annoying bug. I have a Jabra headset and a Jawbone II which I'm going to try to see if the same thing happens.
I have since tried two other brands of BT headset, both have the same problem.
HTC says they have had no other complaints and it must be the headset (translation: we're not going to fix it). This was b4 I tried out the other two headsets.
I'm going to wipe and see if that fixes it.
Update: Wipe seems to have fixed the issue. Used it for almost two hours.
Now to restore my apps and settings and see if it's still fixed.
This is wonderful.
Called HTC for the third time. They put me on hold, then came back and told me that, because the Bluetooth connects, and I am able to hear part of the conversation, there is nothing they can do!!! They said they cannot guarantee Bluetooth will work!!!
Can you believe that???
"Hey, buy our products. we just can't guarantee they will work!"
Great business philosophy
So I proved to them it is their product at fault and not the different ear pieces I've tried. And it only started AFTER Froyo.
And they basically told me to go frack myself.
