Root 2.2 memo apk??????
Eris_2.1_2010
I'm running superclean 2.4 and there's no memo pad. My question is was there a memo apk for EBO1 2.2. If so where can I get it? Thnx in advance.
Install unsuccessful and moved to system/app and still unsuccessful. Any ideas?
After installing 2.9.2, I had the same problem:mad:. I lost the memo and all my memo data:mad::mad::mad::eek:. Titanium Backup had the data, but would not restore anything:confused:. I downloaded the memo.apk from the above link:D, used Root Explorer to move it to systems/app from the sd card, (do not try to install it) then rebooted and memo was there, but empty. Then I went back to Titanium Backup and restored the data. Problem solved:D:D:D:D.
Again, do not try to install it because it will show a failed to install window. Just move it and reboot.:cool::cool:
Thanks for the link.
