Help 2.2 OTA Failed? Help!
hllwyh
Last night I did the check updates *#*#2432546#*#* and to my surprise a few minutes later a system update appeared. I was elated and accepted the download and restart. I am still waiting... I have the explanation mark and the little android guy on the front of the screen, but no restart. What do I do next? I am in a slightly weak area, but normally can get 3G and decent downloads. So now I am unsure how to proceed. Was the restart suppose to be automatic? That is what I was led to believe. Any suggestions?
Can you take a pic of the screen? Does it have the little android guy with an arrow coming out of the box or just a triangle with a ! and the android in front?
No arrow just the triangle with the explanation mark inside and the little green guy to the bottom right.
Hmmm... Hit the Power Button and Volume Up at the same time and see if a Menu comes up.
If so, there should be an option to Install: update.zip
Hit that and see what you get.
Yet it gives me four choices:
Reboot system now
Apply sdcard:update.zip
Wipe data/factory reset
Wipe cache partition
I would guess the top two are the best choices in this situation. Should I apply the zip file?
Reboot system now
If that does not work, choose Reboot system now, but make sure you write down the error message.
If all else fails, try to do it manually. I write a guide here:
[How-To] Stock 2.1 or any 2.2 build to latest Froyo (FRF91) - Google Nexus One Owners | Google Groups
Thanks.
I should mention that the update was aborted as shown in the yellow type below. So Perhaps choice one is best.
Ok I decided to reboot the system and it came back up. I will attempt the update once again from a better coverage area. Thanks for all of your help!!!
Oh, that makes a diff... :)
I would try and download and do it the manual way as stated in my last post.
Download the files with your PC, copy to SD Card and rename it there to make sure it's not messed up.
Remember, filenames are Case Sensitive! Make sure it's all lower case:
update.zip
Thanks.
I could not wait so I found a good area in the house and initiated the update again I got the white box with an arrow coming out. Things are going much better this time.
Sweet! That screen may take a while to finish so DO NOT MESS WITH YOUR PHONE!!! Let it finish!! :D
Froyo success!!! Thanks Talderon!
No problem, glad it all worked out... Now, a couple hints to help you make it smoother:
1. Reboot again after it is fully running
2. Reboot back into recovery:
--Power Off
--Power on while holding Volume Down
--Press Power and Volume UP at same time again
--Select: Wipe cache partition
--Reboot
This is what I normally do after every update and makes it run smoooooooooth as silk... :)
This will NOT wipe ANY data at all! (FYI)
--Power Off
--Reboot
Hi Talderon,
I followed the above after installing from ERE27 to FRF91 via OTA from google on friday morning here in UK.
I still suffer that memory problem, as its still showing my phone memory to be 23MB (out of 196MB). Its very heartbreaking as its one of my main froyo advantages.
im out of all ideas really, currently considering the ultimate which is resetting my Nexus 1 back to factory setting and wipe everything (i even hate saying it).
:confused::confused::confused:
Please advice.
Thanks
Hi Talderon,
Please advice.
Thanks
Try this:
Settings / manage applications / all
This will bring up all your apps. Go menu and sort by size. This now shows what apps are using the most memory. Go into each app and try to clear as much space as possible (data and cache). Some you will want to leave but some you can clear.....
What screenshot?
I think poor me, its my mistake.
My RAM is increased tremendously to say 240MB (with only 2 programs running) and like 170MB (with 24 programs running).
I was referring to my phone's internal memory:
Settings> SD card & Phone storage>Internal phone storage (for now i have available space of 38MB) from the total of i think 170MB or so.
DID ANYONE HAVE HIS PHONE's STORAGE INCREASED by froyo?
Thanks
In other words, froyo does not address the internal storage problem then. Apps to SD still did not work for 99% of apps. Even those claiming supporting it like Carrom3D failed to move to SD. with 38Mb remaining if i install 2 or more apps, i'll go below 20MB and i wont install anything again.
so did your froyo increased your storage from 196MB to something higher?
Nope...still @196MB internal Memory on frf91 :mad: I see more (unused) RAM opened up...but not for internal memory. Really did hope that Froyo opened up more internal memory >_<
I've already reset my phone back to factory setting, lost everything. I realised that my contacts were'nt saved on gmail as should. I back up SMS before resetting, all my messages are back. Apps and settings are saved on google servers, thanks to froyo and i was able to get them back.
Why did you have to do a factory reset?
