Root 2.2 SBF Did Not Fully Restore to Stock?
antnyh
OK, this is weird. I have already used RSDLite 4.8 and the 2.2 SBF file to flash to stock once with this phone. Last night I wanted to flash back again in order to make a backup, like a dummy I forgot to last time, and try a new ROM. The RSD program ran great, took about 10 mins. Completed successfully and phone rebooted. Once it booted back up I didn't have to go through the phone setup and LauncherPro was already my launcher. None of the blur was put back on and all of my apps were still loaded and accessible. I did loose root though. Anyone experience this? If so what happened? Here is my setup. BTW, I restored a backup so I am right back to where I was before the flashing.
Froyo 2.2
APEX V1
No clock mod
Revolution Theme
That is it other than apps that I have DL'ed.
Yep, the SBF leaves the data partition alone. The reason so many people are confused about this is because they used the SBF to restore to a different version of Android (e.g. downgrade from leaked 2.2 -> 2.1). If you remember correctly, part of those instructions were performing a factory reset.
You can SBF all day long and it'll leave all of your apps alone.
Funny, I don't recall doing a factory reset last time. So in other words there really is no reason to SBF once you have the udpated 2.2 unless you brick the phone? If you just want to revert to stock, like me, you just need to factory reset? Thanks.
Umm not if you're running Apex. Doing a factory reset will just give you a clean version of Apex, not the original Moto rom. If you want the original Moto rom then you'd either need to apply an update.zip, restore a backup, or yes use the SBF.
