Root 2.3.15 leak Contacts FC
Pointguard1122
Is anyone else having the conttacts force close on TBH's 2.3.15? It does not FC when you selesct the dialer, but if you select the contacts app directly or if you select contacts through the Car Dock it does this. 2.3.9 did not do this.
Just the one, I am going to try a SBF and see if it fixes my audio issue. Otherwise, I will simply live with it until my replacement phone gets here. Good to know it is not in the update itself. Thanks guys.
I flashed back to 2.1 today, rooted, installed bootstrap, installed 2.2 rooted, deodexed, then when I upgraded to 2.3.15 my contacts are closing as soon as I open them. I even went through the whole process again and I'm still having the same issue. Any ideas?
Update: On my third attempt I did not wipe data or cache before doing the 2.3.15 install and the contacts are now working.
That is good to know AirMaxx. I was having trouble until I updated to the R2D2 update. Now everything works great. I just did a Data Only Nandroid update to get all my stuff back. Contacts work great now.
