2.3.3 bluetooth dialup
zummolo
Hi,
I used my P500 to tether my lapto (Seven x64) and connect to the internet.
It took 1 minute to setup and worked great, using "generic bluetooth modem".
Today I upgraded to 2.3.3 (no brand) and now I cannot dial the internet anymore.
The connection from the P500 itself works 100%, but when I dial from the PC it stop after "verifying username and password" and stops on "registering on remote network...".
If I look the main screen icons, I see the "Data" icon (the two arrows) disappearing and reappearing, then after a minute the pc says I cannot connect.
If I use the hotspot mode (as in this moment) all works great, but the battery runs for some minute only...
Someone having the same problem?
Any ideas? Is there a way to switch back to 2.2?
Thanks
