Kalokagathon
I got a problem. This is complex, so get a beer.
I updated to 2.3.3 today, and the phone performed just fine for a couple of hours after powering back up from the update.
For no reason that I know of, HTC Sense suddenly started trying to reboot and got caught in a loop that would only give me the option of Force Close, and then start the problem all over again. The only solution I found was by using the search button to get voice activation onto the internet, where I downloaded Launcher Pro. Used launcher pro to reset data for HTC Sense in Manage Applications>All (this completely resets your interface to factory, but it doesn't delete any data like email, texts, apps, etc.). This allowed HTC Sense to boot up normally, and give me a chance to hunt down the problem, but I had to re-do my Home Pages all over again.
I couldn't find the problem, so I downloaded the little 4MB update, and started re-doing the home pages when the phone powered back up from the small update.
The first thing I did was remove the large clock widget (which strangely wasn't showing any location or weather) and try to add the smaller, rectangular stock clock widget (the 14th one out of "Browse all HTC widgets"). When I hit "Current Location," the HTC Sense reboot loop started all over again. I did the whole fix with Launcher Pro again, but this time when Sense started up normally my mail app was missing. I went into Manage Applications and it looks like both the mail app and all my mail accounts and info are gone. The Mail app is still in the Manage Applications>All list, but it says 0.00B and it's not running. Can't figure out how to get it to run.
Now here's the thing: I've tried to see what else could be causing this HTC Sense reboot loop, but the only thing that starts it, that I can find, is that one widget when you hit "Current Location." No other clock widget does it, even if I hit "Current Location." No other app starts it. Also, none of the clock widgets will show my location in the widget itself, but it will show it while I'm setting up the widget, if that makes sense.
Also, after the second Launcher Pro fix, the mobile network had a real hard time turning on. It just said, "Turning on..." for about half and hour.
So, here are my questions:
1) Anybody else have this problem after these two most recent updates (Gingerbread and the small 4mb update)?
2) Why would a clock widget's current location option cause HTC Sense to lose itself and go haywire?
3) Why did I lose my mail on the second reboot loop fix, but not on the first? Why did I lose it at all?
4) What in the world does the clock widget (the 17th one out of "Browse all HTC widgets") have to do with mail?
Does anybody have any idea what's going on? I'm hoping to keep this sort of thing from happening in the future.
