2 Best Android Keyboards
I've summed up just about the 2 best HTC Wildfire (well, probably android) keyboards. You use them both in a different way.
1. Swype
You cannot download this from the app store. To use this, go onto google.
Search 'Swype' and click the first link, or just click Swype | Text Input for Screens to go to the website.
That has some information on the application so you can see what it's like.
If you want the actual application itself, you have to go to a site that you can't access using the homepage. This is the site:
Open up the email using your web browser on your PHONE. It's recommended.
Enter your email and password on the application once you've installed it and after that, you'll have to type in a code you recieved in your email.
If you are using opera, after the file downloads it should automatically let you open it.
If you don't have opera, then download on the app store Astro File Manager. Just search up Astro, and you can browse via that.
For swype, there isn't constant tapping on your phone, it's swiping.
Here's a demonstration:
‪Swype Tips: How to Swype‬‏ - YouTube
Swype also comes with it's own tutorial - that's handy too.
2. iPhone Keyboard Emulator
To get this app, go in the market and search up 'Emulator'. Then, scroll down a bit until you see this app.
There isn't much to say about this app. It's almost exactly the same as the iPhone default keyboard, and thats all there is to say.
It's much more accurate, lots of people say. I personally prefer this to the android default and others.
You can decide which one you like best, though.
I hope that this post helped you :).
I've tried a few different keyboards from Android market as I didn't like the one that was already installed on my Wildfire. At the moment I'm using SwiftKey X which I really like. I did wonder about the iphone emulator keyboard but was unsure if it would be suitable for a Wildfire. If I ever decide to change again, I will give it a try.
