Help 2 gTab questions..
Hello all...I've got an Incredible rooted and its been a great tool for more than a year.
Just recently I bought a gTab on eBay...and have two questions:
It's rooted, running vEgan 5.1.1...
The Settings/SD card area reads after the first two lines about available space...
"Unmount in progress"
"Unmount the SD card for safe removal
And I appear to be losing files off the SD card..(mostly pics and video files) and it even deletes files off a USB stick if I leave it plugged in for a while.
Second question...Is there any reason that K-9 mail just wont let me set up even the first account? After entering the account address and password...the [next] button is nonresponsive. Anyone else using this app?
It works great on my Incredible...It is managing 4 email accounts flawlessly..why don't it work on the gTab?
Thanks for any help you folks can provide...
Pete
Pete
Not sure about K9, I don't use that app. As for the gtab deleting media files on the sd card, that's a common issue with the vegan rom. Not sure what causes it but to stop it from happening, either create a .nomedia folder and drop your files in there or create a .nomedia txt file and put it anywhere you have media.
Thanks for that....but I had read that already and neglected to mention that the .nomedia trick doesn't seem to affect the deletion of the files. It still happens at random times.
Also...the continuing message in /settings/sdcard/ "Unmount in Progress" remains...
Someone told me that it meant there was an app not behaving properly to prevent the SDcard from not falling into line? Most file managers can see the files...if they haven't been deleted.
As far as K-9....I got it figured..just had to untinstall then reinstall..maybe a version glitch.
Anyone working on any new mods for this gTab? I really like the vegan...but maybe I should try another?
