Help 2 "How do you" questions
Fred G. Vader
How do you change the lock screen wallpaper?
Also how do you switch out the fixed icons that sit below the home screen dots?
that doesn't rearrange icons on the homescreen .. only on the application screen
The instructions were geared towards how to change the fixed icons i.e. the ones that appear at the bottom of the screen on all home panels. Once you tap edit you can drag and drop different apps into those spots.
and when your done, reset back to alphabetical. I did this to change my icons but was stumped as to why my app drawer was randomly arranged, couldn't find anything.
if you use a note image as your background it often only uses what you painted on top of the background of whatever screen you left it on, rather nifty little visual trick
