Hey guys
Got two really strange ones for you hope someone can help ...
1st
When I have my Captivate plugged in and charging with ringer volume on ( as in NOT on vibrate or silent) when it hits 100% it plays a "ringer"/ alarm tone that cant be turned off until it is unplugged and turned down. It also does this when I receive any kind of notification (SmS , Email, Trillian)but only when plugged in via USB. It is not intermittent , happens every time . Very annoying to say the least . Anyone else able to duplicate or experience this ?
btw : It is not the sound i have selected for those (or any) alert .
2nd
I keep wallpaper and icons on my SD along with a few TV shows etc . For some crazy reason the icons and wallpapers will get multiplied many times out of nowhere, For instance , lets say i have 10 wallpapers and 5 icons in separate folders . ill look later and the Icons will have doubled to 10 and the wallpapers to 20 , later still and they will as much as quadruple . If i delete and re add it acts OK for awhile then it happens again . Weird and annoying ! right now all of the wallpapers on my SD have 7 extra copies and the icons 8 . They all work and are usable but its driving me crazy to have 8 or 9 of each frickin wallpaper . NO OTHER FOLDERS DO THIS , the movies , camera pics and TV shows don't get reproduced . Ive tried renaming wallpaper to different things , No dice
btw : I thought it was the card , bought a new one (different class & size) still does it !
Running (leaked) Android 2.2 on my 2nd Captivate , had it since July ...
Thanks in advance
1st
2nd
Thanks in advance
