Root 2 kernels on an sd card?
can i put to kernels on an sd card and just apply the kernel from the sd card without having to re-flash my phone everytime with the sprint update tool?
ok first off you do not flash a kernal with the updater tool you use recovery to do that .and yes you can have as many kenals as you like right now i have about 8 on my sdcard but if they are in zimage form you will not know which one you are flashing but if you keep them in zip format then theres no problem.
