Help 2 Kies questions
jameslink
Hi all,
Just made the switch from iPhone to GS2 and need some help with Kies, if you would be so kind.
Question 1)
Is there a way to stop old episodes of podcasts showing up again when you update the feed? This is very frustrating, and makes kies unusable for me.
If not, can anyone recommend a PC based podcast client similar to iTunes that will work with this phone? Is there maybe a way for me to just continue using iTunes? I subscribe to over 20 podcasts, so device-based management like stitcher is not an option.
Question 2)
I cannot get my device to show up using wifi. Any help for this?
I think the problem may be that my PC is connected to the router with a cable instead of wirelessly.
Thanks in advance!
