2 Nexus 4 questions... Pouch and Charger
eric0668
1. I am considering using a bumper, I haven never used one. I would only use with a pouch (which I have seen but never usedd) due to the glass on the Nexus 4
I was looking at some smooth, fine grain (Not sure of the term) leather (not real leather undoubtedly) ones on eBay I love all the colors
Only problem I emailed the seller and they said it would not fit the bumper. I had the idea of going with the S3 and they said, No also, the screen is bigger, but the phone is not that much bigger
could anyone suggest a pouch to a phone that would work with a bumper. Or even a specific link? I also don't want to get too big of one. Would you think the Note II would work, or would that be too big?
2. I asked on XDA because I was told otherwise in Best Buy, but a case would work on the Energizer qi Pad. However, most said it had to be situated just right on the pad to charge. And a couple said that it gets a little hot the thinner the case. So a Catch-22
Anyone used it and can vouch that it is very good
Or, it seems like the more I look into it, it is just a novelty and I should go with a Destktop dock?
Thanks for any input
