2 problems folders and video
ok so i have made folders, the folders will work then after a while it wont let me open the folders anymore, so ill have to delete them and remake the folder with everything inside of it. is this just a glitch or somthing? anyone else have this problem? is there a cure? i just restarted the phone and now the folder seems to work again, but i will give it time untill it does it again. its a weird problem
other problem i had today i was driving trying to get a recording "video" and i would press record and it just made the sound like it was starting but nothing was happening, i checked space on my sd card and i still have like 13gb so im good memory wise. and again restarted and it works like a charm. i guess if all i have to do is restart then its not a huge deal, but just curious what you all think is causing this.
and as a side question that ill probably get a use the search button is when is 2.1 coming out :P
hmm interesting. I use folders quite a bit, and have not run into this problem.
(Android 1.5)
I've noticed this happen on mine a couple times. it only seems to happen after installing updates to certain apps. restarting the phone fixes it and it only ever happens again after installing more updates...
