Root 2 problems..
incrediblenotinstock
My phone isn't vibrating for texts. And also my 3g is screwed up I can't go to any website within the browser and the 3g isn't working for apps that need it. Ex. Newsroom. Does anyone have a fix ?
I had this problem at one point on fission. What kind of specs are you running. And is this all the time even after a reboot or periodically? Mine was periodically and I fixed it by toggle on and off plane mode.
+1
nerver had the vibrate issue he is having though....
I got the 3g working but not the vibrate
Get into the stock text messaging app.
Click the hard menu key
Touch settings
Scroll to Notification Settings and touch it
Touch Vibrate
Select Always (or whatever you want)
That "should" do it.
BTW, it's the same way for email apps to, vibrate is now more optional, but you have to select the option within each app.
Touch settings
Touch Vibrate
what if I'm using comp sms
Chomp should have its own settings menu where you would have to enable this setting.
downloaded chomp to check lol
settings
notifications
vibrate. -- always
set vibrate pattern
