Help 2 questions....
hi guys hope you are well.
1) is there any way of changing the time input on the calendar and the alarm to a keypad in stead of the incredibly annoying "wheels"?
2) any way of setting exchange mail profiles to have "peak" and "off peak" settings? i want push for 9am to 10pm but then off at all other times....i dont want to get woken up at 3 am by an email!
cheers and thanks!
1) You can't change it, per se, but if you tap on the number it'll give you a direct text input option where you can just type the numbers.
2) LightFlow can take over your system notifications and will let you set do-not-disturb hours. Try it out; there's a free version to try, and you can buy the full version if you like it.
