Depends on the coverage of wifi in your school. If the coverage isn't good enough, your phone might accidentally switch over to 3G without you knowing. But there are apps on the market that allows you to disable 3G.
I think most of my usage this month came this last friday when I showed a few youtube videos to my dad in his garage where I guess I was on 3g instead of wireless.
This is the difference between your usage habits on 2GB vs. 200MB. You simply have to be aware of it. Rest assured that 200MB is well more than enough if you're willing to flip an on/off switch as needed.
Yeah and if you're willing to pay five bucks more for about 2.5gb less of data per month (in comparison, if you happen to go over in both plans)
The question "Is 200MB enough?" assumes that the answer is "no" if overage fees are incurred. Thus, your point doesn't belong on the table for this particular discussion. It's not about the best value (money vs. data), it's about a particular situation: low costs are important and wifi is in abundance. For this case, 200MB is easily manageable.
thus alas indubitably perchance leather gloves tinted windows 400 year old bottles of wine : I gave my answer and it's not for you to dissect, it's for the op to take and apply to his question as he sees fit.
if I live at home with wifi
and go to school with wifi..
and I only occassionally use GPS(maybe once a year)..
The only thing being updates would be widgets every 15-30 minutes..
Would 200mb be sufficient?
