Root *228 not working after Root and going to Froyo
khanusma
Thanks in advance for any assistance.
I decided to try to goto Froyo. I have never previously rooted before this experience.
I followed the instructions here and on the internets and was successfully able to update my phone in the following order:
> Radio OTA leak
> Unrevoked3 Root
> Froyo ROM
> Market fix "fingerprint_froyo.zip"
Now I am unable to *228 and program with either a 1 or a 2. The message "programming in progress" does come up but after about 10 seconds, the voice tells me that I cannot update at this time and I should call customer service.
Does anyone have any thoughts on how to troubleshoot? I assume its due to the upgrade and not a coincidence.
Not that it's the same issue as when I used to load blackberry OS's but every now and again that would happen where *228 would not work. I always thought it was something I did wrong... But after discovering it worked later, i'd just wait a while and try it again... Sometimes the ota activation programming is down for some reason or another.
and why wouldn't you do *22899 instead of *228?
I fixed the problem. I went to bed and woke up and now there seem to be no issues. Works for me :).
Obviously I don't know what happened to resolve the problem but *228 1 and 2 are now working.
Thanks for the responses.
Not to sound overly noobish but what's the difference. *22899 I just tried seems to just go straight in. What does it do differently or is it just like going straight to option 1?
*22899 does both options automatically without you having to do *228 then option 1, reboot, call *228 again and do option 2. Saves a little time and effort.
