D
Deleted User
Guest
I don't know if anyone else has been using a different DPI, but has anyone been having font and background color issues on 240 DPI?
Seems like when I set the DPI to 240, in some apps like Google latitude, when hitting the menu button, the font is white along with the background being white making the text non-existent.
Another thing would be the notification bar, some fonts are light grey while the background notification pull down color is grey, which just makes it a bit hard to see without really looking.
And one last thing I've noticed was hitting the menu on home screen or any type of dialog box on the home screen has a very transparent look. Just another inconvenience without really looking.
There may be more but these are the ones that I've noticed. I was just wondering if anyone else ran into this problem or had a fix for it. I will try to post pictures when I get the chance.
