Help 2nd Evo - help
gnarlyDUCK
I just got info that my 2nd Evo should be in my hands tomorrow afternoon.
I need to ship back the original evo due to its shattered glass.
What do I need to do to the 2nd Evo to mirror my 1st Evo? I hope everything should be pretty much automated, right?
My contacts should just resync themselves from Google? (but they havent on my Hero as at the moment i use it for backup).
I have AppBrain and can re-push my apps.
And then I have the SD card which i can just swap out.
.... but would there be anything else I should do before using the 2nd phone?
if you had 5 bux you could use mybackupPRO which would do all of that. i used that when i did a hard reset.
go into sync all so google will make sure all is updated. if your contacts are within google then yes they will resync.
appbrain is a good choice and es file explorer backs up as well.
you have all the bases covered bro...
Heres what the process looks like for anyone interested....
All done! :)
