KrazeeCracker
Which one will save me more battery life lol, i know they do the same thing, but a lot of you are recommending 2x battery? Why?
are you talking about an extended battery?
So should I get rid of my Advanced Task Killer app?
When I first started using it, my battery life on my Optimus M doubled from 4-5 hours to 10-11 hours.
Over the past 6 months this has gradually decreased to where I'm at 4-5 hours even using the app. What gives?
Maybe it's due to the batteries I use getting progressively older.
Brilliant answer by Aere also in addition battery saving apps screws with the Apn setting so unless u know hot edit the apn again u will be left with no 4g data, those apps are useless if you want to make life easier get switchpro widget has shortcuts to instantly turn of data background data flashlight built in task manager if u want then a rebooter to go in recovery etc all in the widget
Now if you get a feeling that your phone is running slow/sluggish/or freezing. Then that's a different issue. That's the hardware on your device.
If you don't have a lot of RAM to handle more apps or your CPU speed is slow and can't process multitasking smoothly, you'll get that type of experience.
can we please review 2x battery? anyone?
What are the odds of either one messing up my apn settings though?
I've tried out juicedefender and it seemed like it wasn't gonna do anything more than what I could do myself with a toggle app. 4G is more or less the reason for serious battery drain and all you need to do is shut it off and only use it when you need it.
