Help 3 Application Questions..
eric0668
I have to ask you a question that it has been posted here and in several forums and I have waited the usually asked for 72 hours..
1. Is anyone familiar with NoLed App? If so, I am Baically, Generally, Overalll, etc...confused. I cannot get it to work. I have to find a site to read up on it. But my main ?, does it work on the Galaxy S 2 as well as the original Galaxy for which it was designed?
2. I am also trying to use LockBot Pro. Why does my SGS2 on Tmo lockscreen periodically come back, and replace the Lockbot one. Just periodically, but quite bothersome
3. Lastly, I have beautiful widgets. I have unchecked "unlock animations" yet when I awaken my phone before unlocking, it takes an extra couple of seconds because there are STILL clouds flying by
I don't know how to stop them with a setting (preferred way) or even by removing one of the several apps that are installed to make it all work
Thanks so much
The NoLED works fine with the S2. Important: make sure that your original lockscreen is enabled because the program relies on that to work.
