BlackGravity
I flashed my ascend to CM6,everything went ok but on the first boot and after the start up my phone looked just like it did before the flash....my wallpaper was the same and most of my app were still there,it did flash it to 2.2.1 but i thought it would have made the phone like new,you know have you run the set up and all,but it didnt is that normal?
the second issue was my WIFI,it wouldn't stay on,as soon as you click to enable it.. it would just shut off.
and my third, after seeing the issues i was having i just flashed back to the backup i created,all was good back to my stock everything working until i tried to use Link2sd...when i start L2sdit gives me the option to choose the file system of the partitioned part of the sd card,but after i select it i get an "Mount script error" says mount script cannot be created. Mount: invalid argument.
i used the latest CM6
thanks
thanks
