Help 3 issues with my Galaxy S II
d34th1457
I'm currently having 3 problematic issues with my Samsung Galaxy S II, which are...
1) Cannot make/receive calls or send/receive text messages.
2) When I try to change some things in Settings>Call, it says 'Network or SIM card error' and some of the options are greyed out so I can't change them.
3)When I try to connect to a Mobile network in Settings>More...>Mobile networks>Network Operators, it says 'Unable to connect. Try later', it happens with all of the available networks which are Virgin,O2 -UK, 3 UK, virgin (Yes, it was repeated) and Vodafone UK.
Any help or advice would be greatly appreciated...
The model of my phone is I9100.
By the way, I've put in a new SIM card and it has solved problems 2 and 3, I haven't tried calling anyone yet, so I don't know if problem 1 is solved but nonetheless, my luck seems to be improving and I may have a solution to the issues I've been having.
If the problems occur with the new SIM card as well, I still have one last spare card to use.
Great news!
By changing the SIM card, I can now call and text! Now I know that if it happens again, all I have to do is change the card. :D
