Root 3 questions I have.
M
Member 893895
Guest
Alright i wanted to just post all the questions i have here instead of making separate threads.
First off im running playfulmod 1.1(froyo) and im with MetroPCS
1.Is there a way i can overclock to 710mhz like in cm6 and cm7?
2. After using uot kitchen to create my own theme i now have a problem where the buttons and the trackball no longer light up. Is there anyway to solve this?
3.Is there a way i can make my status and notification bar black like with the icarus 1.1 mod?
4. Are there any tweaks i can make to build.prop?
That's basically it.
That's basically it. and also with question #2 i did the metro off fix but it just got rid of the roaming indicator off but i want MetroPCS to show there again as well.[/QUOTE]
Go to data/data/eri.xml in the file explorer edit eri.xml everywhere it says eritxt"" put MetroPCS in between the quotes
Ok that fixed the problem but now after using metro off my 3g stopped working
No it didn't because i made sure the first thing i put was that im running playfulmod. I didnt change that. but i have another question. Whenever i flash to cyanogenmod 7 i always have a weak signal strength. is there anyway to solve that or is that just apart of the rom?
I've heard that it reports weak signal, it doesn't actually have it. To confirm it one would actually have flash between CM7/6 and stock (or PlayfulMod) go to a precise area and look at the dBm in signal strength. Even then it's not a sure shot...
