kobrapack99
Member
Ok, its not my data. Are u guys using battery indicator pro?
are you using no lock,it would not let my evo sleep
any news from Battery Boss?!
can someone help me out here. I have the battery posted in the original post.
this is now my 3rd full charge. I've let it completely drain 3 times and fully charged 3 times. Should i continue doing this or just charge as needed now?
Today i have an up time of 11hrs and awak time of 3.5hrs. i've done alot of 3g web browsing today. I'm at 50%. Is this considered good? I mean it's alot better than my stock battery but should i be getting more out of it? gps is off.
are you chargin in the phone or externally?After my 2nd charge, mine lasted about 20hrs w/gps and wifi turned on w/about 3 hours of games, maybe 1 hour of internet usage. This got it down to 10%. However 2 hrs of the game play was toward the end of the usage. I have no baseline and have no idea if this is good.
well it is, but i'd like to get the most out of it. I've changed every setting possible to help my battery.Is it enough for you? If so that's all that matters. I wouldn't drain it till the phone dies just drain it down to about 20% or so.
thanks for the info!The battery will reach max capacity in about 6 charges or so. If you get the same performance from the last half of your batteryas the first half you will get about 7hrs awake time. IMO thats pretty good. Remember that 3g web surfing can KILL you battery if you dont have a strong signal. If your signal is low like 2bars it will eat your battery faster than if you had 5 bars
i don't think there is cases yet but the case that comes with the battery in the first post is very nice and looks stock!so are there any actual cases that are colorful that dont need to be modified to fit this phone with the chinese battery?
I only get 1 or 2 bars in my apartment although i surf using wifi, I'm sure that hurts my battery usage.
I charged the battery in my phone all nite powered off for 9 hrs+.
im thinking that using wifi will actually save you battery if your in an area where 3g is low. It probably wastes more battery searching for the 3g signal than your wifi.
