71Makaveli96
ok so i decided to bite the bullet & order a 3000mah battery, now can some1 recommend the best external charger
Ordered my 3500 with back door, and my external charger tonite. Will post back when i recieve. Curious as to how much im gonna be getting outta them. Myn's 2.2. Stock kernel. We'll see.
Mind sharing who you bought from? Thanks!
If your rooted you can flash a new kernel which makes an external charger unnecessary
yeah its not that much better then stock.. only thing good is it feels better in my hand.
Anyone knows if there is a (cheap / easy) way to measure a battery true mAh readings?
So that if I buy a battery rated at 3500 mAh that I am getting a battery close to say 3500 mAh and not a battery giving me ~1500 mAh?
