32 GB MicroSD Card - $20
Doesn't say what class it is.
What do you think the "C" with a "4" in it means >.<
*Sigh* Anyways, I have one of their class fours, and it is outperformed by a samsung class 2 so don't buy it, the read, and write times are shit!
Go to newegg, and look at their class tens. You can get a TRUE class 10 for about 30 bucks @ 16GB
Looking at this one right now: Newegg.com - G.SKILL 32GB Micro SDHC Flash Card w&#47; SD Adapter Model FF-TSDG32GA-C10
But there are so many.. I dont know which ones the best, mostly all of them are fast speeds.. Just what brand you want..
you know whats a good one?
Good pick Kush! Glad to see that I helped you pick out something worthwhile instead of something that would have disappointed you. 16MBwrite is pretty damn good for a C10 from what I've read most of them are barely able to break 14 although 20's the max, so that's pretty good for 30 bucks...I'm ordering one myself if I don't find anything better within the next few days.
Yup, Thanks for the tip. Added the Rush Delivery for 2.99 lets see if it gets here by Saturday.. Got my fingers crossed.
Still waiting on my $20 to get re-enversed now.
Newegg.com - Patriot LX 32GB Secure Digital High-Capacity (SDHC) Flash Card Model PSF32GSDHC10
what do you guys think of this one? I think its a good price for a class ten but a little sketchy any ideas on the max write read speeds on this one? also by curiosity does the connect support UHS?
well i bought it, when i get it ill let u guys know what read and write speeds i get with it.
According to a few people on there the patriots have had issues handling large files, which leads to question how they'll last. I'm not as worried about performance as I am stability. I like knowing the umpteen thousand pictures I'm taking of my newborn will stay a while.
Also, at Kush, the "rush processing" that you ordered from newegg will get it out of their warehouse faster (possibly) and if not, they'll refund it.
I've used it several times before, and they had to refund it simply because the warehouse my item was shipping from couldn't get to it by noon. But even in the worst case scenario they'll get to it by the end of the business day, but it won't be on that days truck shipping out so it's worth the three bucks.
When you get it, benchmark it for me. I'd love to see how it holds up.
yea i was reading some of the comments as well but it didn't seem like a whole lot of people were having that problem so I'm assuming they just got defected ones well in any case I'm going try it and report back after i do
Dont get that one, that wont even fit in your phone! You see how big that thing is?
Those are for like cameras...
Id recommend getting the one I got on NewEgg, Posted above.
well i actually got it for my camera the question for this phone was if it supported UHS micro SD cards or some of the newer faster micro SD formats
From what I understand of UHS-1 it wouldn't really be beneficial for phones anyways, because the main difference between it and class 10 is that it empties it's cache faster, and that's about it. As for speeds, they're still the same.
they are supposed to have faster write and read speeds and much better bus speeds that said since i don't know if those work on this phone i guess ill look into some class 10 I'm stuck on four of them right now.
Newegg.com - Transcend 32GB Micro SDHC Flash Card with Adapter Model TS32GUSDHC10
Newegg.com - Patriot LX Series Class 10 32GB Micro SDHC Flash Card Model PSF32GMCSDHC10 &#40;32GB&#41;
Newegg.com - Team 32GB Micro SDHC Flash Card Model TG032G0MC28A
the first 2 are compatible with the 3.0 standard while the last 2 are 2.0 what do you guys think I'm leaning towards the first one.
3.0 would help if connecting it directly to the computer, and having a 3.0 compliant slot.
The thing I should point out here is that the USB 3.0 compliance will have no effect on media card readers unless they're designed to take advantage of that on the native connection to the motherboard (unless you're using an external, in which case it'll still need to be compliant on the reader, and use a 3.0 usb slot.)
The xfer speed to computer really would not hurt much, as most media cards still aren't even reaching the read/write speeds of standard USB 2.0 so I don't see it making any difference to be honest, and a 3.0 compliant device will still work just fine in 2.0 slot, it'll just slow it down a little, but as stated the card can't even read at usb 2.0 speed anyways, so yeh.
Also, the transcend has no reviews on Newegg, indicating it's new, or people just don't trust it, and since that's the case you have no benchmarks to go off of to make sure that it's actually NEAR 10 speeds.
The thing to note here is that classes on SD cards are for the Maximum read/write speeds. there's no guarantee you'll get what's advertised.
So I say just go with the gskill, it's cheap, has good reviews, and will do what you need on the phone.
will i wanted a 3.0 one because i do alot of transfering from my computers and phone and what not i use my phones as a usb stick must of the time with very large files but yea you got me with the no reviews =/
SD Card works great! and Super fast compared to the original 2 GB card it came with.
Loads really fast at start up.. and I can run games very smoothly.
Well i seen your other thread about random reboots. One of the reviewer for this card is having that problem and he said it stops after removing the card. Do you think its related?
Thats a good observation.
I will monitor by using my old SD card to see if It resolves the issue.
Also, what I might do is just copy the data onto my desktop, then erase everything off the sd card. then manually reload the sd card with my data.
As those where the steps on fixing the same problem I had on my old LG Optimus M.
Sounds good let us know the verdict. I really do want this card the price is just right.
I honestly don't think its the card that is causing the random reboots.
The card itself works like a charm! extremely fast at start up.
Also, now that I can remember... It did reboot a few times using the standard 2 GB Sd Card.
I have not got a random reboot the past 2 days.
Like I said It doesn't happen frequently..
Last week I did go to the Metro Corporate store and told them about my problem, they preformed a factory reset and updated software. (they logged it in to computer)
So they told me if I keep having the same problem, Just bring it back... they might have to order a replacement phone.
This is a good SD card. but I am sure if you pay an extra 5,6 bucks you can get another one with TRUE WRITE/READ speed. This one is great! but It would be nice if it could be as fast as advertised.
