32 or 64 GB?
quarkrad
I have just purchased a 10.1 GT P5110 model and would like to by a micro sd card for it. The manual says the max capacity is 32GB but I have read on the net that you can put a 64GB card in it without any problems. I've also found out there appears to be a number of variants - e.g. I have a GT P5110 model. Does any body know if I can fit a 64GB into this model or is it 32GB? Any advice appreciated.
I think it is best to just follow the manual. Who knows? You may cause problems to your SD card or tab after some time of usage.
I want tot use 64 GB card to and now I am using a 32 GB. But I just up grade my firm ware to Android 4.2.2 and what red on a forum that now I can use a 64GB card. I have a Galaxy Tab 2 10.1 ( GT P 5110 )
Good luck
Look at the screenshots I have made
Here's my experience
http://androidforums.com/samsung-ga...cro-sd-card-issue-re-playing-video-files.html
