droid newb
I bought a 32gb SD card for my Epic as I really need the space!
So I took my 16gb card, plugged it into my laptop, copied all the files to a folder and removed it.
I put the 32gb SD card into my phone, formatted it, removed it, plugged it into my laptop, dragged all the files onto it, removed it, put it back in my Epic and none of the apps that were on my SD card will run.
The Epic shows the massive amount of storage from the card, but it simply will not run any of the apps on the card.
Did I miss a step? Did I do something wrong? Can anyone offer any advice?
This is driving me crazy so any help is appreciated!
Thanks!
Thanks!
