Accessories 32GB vs 16 GB included SD
DrH
So a FedEx truck will be bringing my Galaxy Tab later today ...
I know the VZW Tab comes with a 16GB SD card included.
Before I start filling it up, anyone have perspective if it is worth the expense to swap out the 16 GB for a 32 GB SD?
Yeah, I know it provides double the capacity ... which might be desirable ... but is it really needed for an average (maybe a bit higher than average) user?
I have the Sprint version of the Tab, with a 16GB card. From an app storage standpoint, you probably won't need it. I have about 80 apps stored on SD, and they only account for about 30% of the card's storage. Media takes up the bulk of the card. If you plan on putting a lot of music (and especially videos) on your Tab, then go for the 32GB card. Otherwise, 16 will most likely be enough for you.
