Root .340 SBF not working. need help
Ageguy
Member
so i tried to sbf back to staock after having liberty 2.0.1 on the phone but after sbf runs the liberty logo is still there. it is stuck just keeps loading the liberty logo. tried pulling battery and still nothing. any help?
After a SBF, or installing a theme or rom, the first boot often takes longer so wait about 5 minutes before you give up on it.
got it fixed guys. thanks. got a little worried and forgot to read some more on the root guide. sorry.
Would you plesae share the instructions you used to do this SBF? There's so many sets of instructions I'd like to see some from someone that's recently done it successfully. Thanks
Get the SBF, Get RSD Lite 4.9, get moto drivers.
Install the drivers.
Launch RSD
Power down. Power up with Volume Down / Camera and power button held.
You will be at boot loader.
Connect phone to the computer.
Browse for the SBF file.
Make sure your device is listed in RSD.
Click start. (Wait a long time. Only unplugged if it says failed. Sometimes it takes 20 minutes or more)
To expand on this (like we need another guide... but all these links are active as of right now)
rqballjh said:
I'm on GB leaked/rooted/deox, from last week, will ytu please share the SBF process you used? There's sooo many threads saying how to do it I'd like to hear the instructions from someone who recently did it, thanks!
Drivers from here Motorola Verizon Droid X USB Drivers & PC Charging Drivers Download | Verizon Cell Phones | Blog about Verizon Phones
Right click on them install as Administrator
Download SBF from http://bit.ly/hfp9iY
RSD Lite from Download RSD Lite 4.9.rar from uploading.com - Filestube.com - download everything
Install RSD Lite as Administator
Turn off phone, Take out battery.
(Right click RSD Lite, run as administrator)
Put Battery In
Press and hold the Volume Down button and the Camera button, and press then Power button until the screen lights up.
Should say Bootloader 30.04 or something
Hook up USB Cable. Wait for windows to find your phone and install drivers (you will here sounds sounds as it installs everything)
You should see the phone at the bottom of RSD Lite. If not click show device. Browse for the SBF file. Click start.
I found it seems to work better if you don't move the sbf window or do anything else on the PC. It may take a long time. It may stick at RAM Bootloader 97% or something for a long time. Leave it be, it will either say phone rebooting or failed.... eventually.
Once it boots it may bootloop at the Red Droid Eye. Go into factory recovery and factory reset. Accessed as below
1. Turn your phone off.
2. Hold down “Home” and press the “Power” button there at the top. Hold them until the Motorola logo appears
3. Release the “Power” button, but continue to hold the “Home” button until you see an exclamation mark (!)
4. Release the “Home” button and press the “Search” key once (and only once!)
Use volume keys and camera button to move around to reset (note that camera button is super sensitive and can double click if you aren't careful)
