3500mAh Extended Battery For LG Connect 4G MS840 + Door Cover New
Im not sure if the anTuTu app is trustworthy or not but this experiment done by @d33ps1x [BATTERY REVIEW] ECell Gold 2430 mAh Lithium Polymer Battery - xda-developers was a good idea. althought it is true that there is a lot of factors that play a big part in the testing but overall it gives an idea on the battery capacity(i guess).Bottom line is can the people with the @3500, @3850, @1900mah batteries and so on run some type of experiment such as this on their battery and also name the battery they have? p.s. Dont forget to post up pics as well if possible....would be very helpful as i too am in the hunt for a better battery than the stupid stock @1540 Bl-44jn thank you
I began using the this battery Gold 2430 mah. Since this battery was made for a different model (the LG connect twin) the battery has to be adapt. Do not just install this battery and charge it, otherwise it will not last as it should.
To adapt this battery it is required to download an app from the Android playstore called Battery Calibrator. Once installed, just follow the instructions and that's it.
It gave me 40% more battery time. It is great.:D
I'm currently at the metro store about to pull the trigger on an LG Connect 4G and would love for someone to upload a pic of their connect with the extended battery and case installed. Pretty please?
Can I get some help got my 3500mHa extended battery Friday and charged for 6 1/2 hrs and I used it after that and got really bad battery life I got 4hrs out of etc can I get some help right now I'm at 84 and been using it for almost a hour this is bad life for a battery help me if you can
