Help 3A car charger
artcwolf
So the verizon store the other day says i need a 3A charger for the car in order to not slow thew charging port down.
If i use anything other than the 2A USB 3 stock charger i will slow down the charging port on the phone and even when i plug it in properly it won't charge like it should.
please tell me if they are full of it or not. Because i've never seen a 3A car charger.
Highest I've seen is 2.1amp
the factory wall charger is 2 amp I believe. If that charger is made for your phone then all you need is 2 amp.
Pretty sure they didn't know how to fix your battery drain issue thus said to get a 3 amp charger.
thanks i figured they were talking out of their collective arses :) I'll keep using the old LG charger for the cars.
