3G/data connection
ajamie123
So I did the qpst and prl update via *228 and had my data going in and out and tried everything posted and couldn't figure it out but now I have steady 3G.. Here's what I did.
After I updated my prl I went to qpst and set it to mob ip and wrote to phone.
Then after that it was fine so I figured I'd try to set it back to simple ip and so I did. Now I have constant data and 3G
Let me know if this works for anyone and I'm running monster v1
Also I have my mobile network as automatic
And you may have to do the network app thats on the prl thread
Damn, this is very very wiggity -__-
I have tried the network app
Thisis what i got from qpst
I have simple IP on
i DO NOT have the @aapk.metropcs.com it is just "@metropcs.com"
On my phone i have metropcs only and data roaming selected.
I am getting of tired of Metro crap. I have had no data for days now! Tried 3026, 3027, going back to stock, resetting all the settings in qpst. Still nothing!
Still working on a fix but I'm pretty sure it could be due to them updating the network because I had data all day yesterday and now it's going in and out
MetroPCS has been upgrading here and there. We're seeing reports from various coverage regions. Once your device configuration is set via the *228 code all you can do is watch and wait. ;)
Whenever I am on 3g on my connect it just goes crazy it jumps to full bars to none it never stays put for more than a second :confused:
I reset my qpst settings and now I have ok Internet access idk but now I can't set it back to simple ip otherwise it will stop working
here are MY default NOTE: This "might" not be the same for your phones but try anyway. Have read that simple ip doesnt like the PRL 03027
Hope this helps :)
Sorry if I screwed up anyones phones it worked for a day then started messing up
