3g data, how I fixed my problem
D
Deleted User
Guest
Aloha from Hawaii...
I was having trouble with no 3g service yesterday, and this is what FIXED it.. hit the menu/drawer button and click on the ACTIVATE icon.. you will see a countdown like 3....2....1 then you will get a ERROR (this is NORMAL, your already activated!) but it will reregister your phone with the network and your 3g should work fine!
I did this yesterday, 3g worked all day, then turned phone off, and this morning the 3g is STILL working!
Try it and see if it works for you!
ALOHA!
ALOHA!
I've tried this. I don't get an error message; it just goes thru the activation process... and, unfortunately, doesn't fix anything.
I had to do this like 2 weeks ago and havnt had problems since and I've rooted and changed my rom
I just tried the advice I found from earlier in this forum and it has fixed the problem (but it's only been about ten minutes so far, so we'll see how long it lasts). I Googled "Virginmobile escalation" which takes you to a site with phone numbers to more local help (ie. not the Philippines). The phone number I called is : 1-866-553-9810. The woman said she was "tier 3" and said she and others on her level came up with this fix on their own, but the engineers are supposedly working on this problem (I pointed out that the publicity they're getting on the web isn't great at this point because of the lack of resolution to this seemingly quite common problem). Anyway we went throught the steps of resetting my account and now it works. Maybe the more people that call this level the better.
The activation did not work for me. But the escalation number did. A real person helped me. I have save that number in my contacts.
It's been several weeks since I have had a problem, but there were times when the activation thing worked, with an error and sometimes without. Lately, the most it ever takes is to turn airplane mode on and off.
I have also solved the battery life problem by geting rid of any apps that are constantly checking the internet.
