cheese_aholic
Anyone out there know if I can use a prepay USB 3G dongle with my Iconia A500 model?
I'm based in the UK.
No reason for it not to work.
I have not tried this personaly, but I am almost certain it will not work. These dongles require software to be installed in order to work, and this software is not compatible with android. What you need is a mobile hotspot that broadcasts a wireless network.
Well, as of today two things happened. My workplace offered to pay my monthly 3G bills, which means I can tether the tab to my phone and not worry about my data charges; and, two a friend of mine lent me his 3G USB dongle and I tried it with the tab. It did not work. The network provider is India specific. As one poster suspected above, I also think it is a question of drivers. But now I guess I won't need the dongle as I can keep the tab semi-permanently tethered to my phone...though I may need a second battery to keep on hand!
Pretty much as I would expect, I bought a prepaid WiFi dongle, works a treat.
Pete
if you have an android phone on 3g you can setup tethering and connect your a500 to your phone as a modem, and use the 3g connection.
