Actually, the signal strength to bars calculation on the Incredible IS wrong.
I frequently show zero bars at -80dbm. However, data works fine at 3g speed and calls are fine quality.
But, the only time i drop out to 1x is when my signal really is poor, -100 or lower.
Sounds like he has a genuine issue.
My signal was at 91. Sometimes it turns back to 3g but sometimes I need to reset the device or turn airplane mode on then off.
Doing a factory reset would mean I need to root again, right?
Seems to only happen when I have bad signal strength, so I'm going to blame it on that for now
